07-29-2024 07:42 PM
I've been using the Freecine app on my new Asus ROG Phone 8, but it keeps crashing unexpectedly. This happens both while browsing through the app and during playback, making it difficult to enjoy my favorite content. I've updated the app, cleared the cache, and even reinstalled it, but the problem continues. Has anyone else encountered this issue with Freecine on their ROG Phone 8, and if so, how did you fix it?
07-30-2024 12:21 AM
Are you sure you have the right one? I just did a search for it and found maybe 40 different apps claiming to be it.
07-31-2024 03:10 AM
I use this app Freecine.
08-19-2024 08:17 AM
I also faced the same issue from that website you mentioned. Please try to use the official website to avoid all issue Freecine Online APK.
a month ago
Hello @Abd56ullah
For this issue I recommend contacting the app developer as there could be compatibility issues.
Also, as another user mentioned, please make sure to download apps from trusted sources, as some APKs could be compromised.
