ROG PHONE 8 PRO Firmware WW_35.1210.1420.111 with more bugs than fixes
Eze2kiel
Rising Star I
After updating to version WW_35.1210.1420.111, here's my experience:
The battery drains very quickly again, as it did before.
I find it STRANGE that they fixed this issue in previous firmware versions, yet the problem persists again with this latest update.
The Wheater app keeps crashing, not updating within the set time.
The STRANGE thing is that they have a fix that doesn't even work either.
The alarm has a problem with the keypad. When you set it and press the OK button, it does absolutely nothing (this problem didn't happen before).
@Titan_ASUS
Titan_ASUS
Community Manager
Community Manager
@Eze2kiel
Hi, this thread will be closed since there is a existing identical thread under processing below. Thanks.
Firmware ROG PHONE 8 PRO WW_35.1210.1420.111 con más errores que soluciones
