Rog Phone 8 can not power on
dinhphuocloc
Dear support,
My Rog phone 8 can't not power even i plug in the power cable
S1AIOC430591WNM (AI2401-5B032WW)
RGI
Sometime battery too low, left it plugged in for 5-10 min. The phone will boot it self. If not your phone have problem
Be sure that your wall socket is getting power. Test cable with other android phone to see it charge.
Mattias_ASUS
Hello @dinhphuocloc
As the user RGI mentioned, it could be that the battery need some extra energy, connect it to the side port and let it charge for a couple of hours.
If your phone does have problems after this, try getting into recovery mode by pressing Volume Up + Power Button for some seconds.
