02-26-2024 11:22 PM
Hi, does anyone know how to remove/turn off the tiny (red/orange) battery icon displaying on top left of the screen when i plugged the charger? Its showing up when the screen is locked while charging.
Solved! Go to Solution.
02-27-2024 02:24 AM
Hi @Rrj01
You can find the setting for it if you go to Settings > Display > Screen light and you move the slider to off
02-27-2024 02:24 AM
Hi @Rrj01
