Cpu is draining my battery?
Chloetolls
I dont know what happened but the first week my phone lasted me the whole day. But now something changed and my phone runs hot all the time idle at 36° I think this is what is draining my battery. If i had to guess it would be that the cpu is running at X mode even if toggled off. I will test this theory later by charging it to full and run it on x mode the whole day see if I have the same battery life and temp.
7 REPLIES 7
Defalt
I've found a temporary solution, to "stop" this you have to change your mode from dynamic or X to the green one ultra battery saver.
I tried this. Its fine when on idle but if I for example use Spotify for an hour it goes to 39° this only happens on this phone other phones don't cook my pocket. I will send logs to admin this weekend hope they find a fix
Tought it worked but nah it's till randomly overheating and even more when I play, even using cooler x, the back part of my phone feels cooler but the screen gets so hot. I've sent my logs to admin, hope they fix this soon.
