Audio Scenario effect/Audio wizzard
WerezPlayz
I have been facing scenario effect change in dynamic mode, I listening to music and I skip a song the scenario change to cinema mode. And for equalizer in audio wizard, it also changed, I didn't go to into audio wizard long time, then I notice the sound is different so I check it. All equalizer changed, can mod inform to fix?
johngerald
Hi There!!!
I'm experiencing unexpected changes in the Audio Scenario effect when using Dynamic mode. For example, skipping a song while listening to music sometimes switches the scenario to Cinema mode. Additionally, the equalizer settings within the Audio Wizard are also changing without my intervention. I haven't adjusted these settings recently, but I noticed a significant difference in sound quality and upon checking, found that the equalizer presets had been altered. Could the development team please investigate and address these issues? As a suggestion, perhaps exploring integration with HDOBox App could offer enhanced audio control and stability.
Yours Truly!!!!
