Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
201 REPLIES 201
A little info here, we can't accept threads as resolved, just OP can.
The issue is being looked at.
Unique77k
Rising Star I
I sent a personal message to Mattias and told him the problems, he told me that they are looking to solve the problem.. Let's hope it gets fixed and they don't make fun of us anym
Do you think the AirTrigger problem is hardware or software?
They have changed the hardware yes. Its no longer ultrasonic buttons. It pressure sensetive clickable this time. The hardware is new so is the software. Software generally takes some time to come upto the speed to give a good experience. So at this point we cannot really conclude if the hardware itself is the bottleneck or it is just software tuning.
Как думаете, стоит ли ждать, что они решат проблему с триггерами или вернуть телефон обратно?
