Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
198 REPLIES 198
Хорошо. Я не думаю, что эта проблема будет решена полностью. Чтобы привыкнуть к новым триггерам, потребуется некоторая практика. Если у вас есть возможность возврата, я думаю, что было бы неплохо вернуть его сейчас и купить снова, если проблема будет решена.
Cheddus
I se lot ofI've watched a lot of videos and once you know what the problem is, you can see that a lot of people do too.
errorTamilan
i search video no use. if i hold trigger it cant rapidly fire that's is problem
ENG430
Any update or a solution for this issue?
Zцlц
Any update? The last update was only solving the cooler buttons. I am on 34.1420.1420.316
