02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
02-26-2024 02:07 PM
From what I see many users have problems with the ROG 8..I personally this is the last time they concern an ASUS product
02-26-2024 11:55 PM
Facing the same issue but slightly more complex.
So the trigers are barelly working. that causes me to instinctivelly press harder. That causes the trigers to go on-off at iregular intervals making gameplay imposible.
To top it off, the right trigger is also activated if i press the back of the phone in a couple of locations which just adds to the problem. Coming from a new Redmagic 9 pro who's triggers were just perfect, (it has other problems though. the Rog phone is better overal) i am now at a cross roads. Any suggestions? is this something fixable in the future or is this just another device for which i will need to get rid off asap?
02-27-2024 01:07 AM
Well we don't know the exact problem that is it possible to fix in future or not. But i am waiting for an update this will clear whole scenario whether it is fixable or not .
After the update if it will not fix i suggest you to switch to another device and never look back toward ASUS.
I will do same thing cause ASUS broken too many hearts :heart_suit:.
I was very loyal customer for past 6 year and they really fooled people this time by charging too much money with zero quality on their trademark Airtrigger and cooler buttons.
02-27-2024 01:08 AM
I will switch to iPad for gaming after the update if they are not able to fix this.
02-27-2024 01:40 AM
When the iphone 15 came out it had a problem with the temperature and too many people said different things apple because it respects its audience and is a serious company solved it in a short period of time.. Now we see Asus having an issue with triggers and from what we see does not respect her audience
