02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
02-27-2024 01:51 AM
@Unique77k @That's why apple is different from all this funky company. They love to hear problems from their customers and work on their specific problem.
Dear ASUS any company or brand can go on top with their customer if you provide only product and don't work on thier problem you will be same like Nokia in future.
@Unique77k Where are you from?
02-27-2024 01:56 AM
Apple is by far the best company, there is no competition.. Their mobile phones may be expensive but they are worth getting and if they have a problem they will solve it within the next few days...
I am from Greece.You?
02-27-2024 02:11 AM
Im from India.
02-27-2024 07:06 AM
I have the Same Problem with my trigger in my 7 ultimate everything worked fine but on my pro 8 the triggers dosen't Work very well thats a shame 😓
02-27-2024 07:14 AM
From what we can see, the problem is with android 14.
