Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
deneskulik
Sajnos én is ezzel a problémával küzdök, a telefon ezen a téren nagyon nagy csalódás hiszen pont az airtiggerek miatt lett megvásárolva sajnos konkrétan játszhatatlan vele a jaték
Altair4300
Rising Star I
Yeah I experienced the same. Exactly the same problem. But now everything is okay. I cleared data and cache of armoury crate ,uninstalled armoury crate. Uninstalled the games. And restarted the phone. Restored back armoury crate. And started the whole process of setting it up , including the pressure settings. And everything was fine
Altair4300
Rising Star I
This problem was also discovered after the latest update, same with me.
deneskulik
Sziasztok! Asus rog Phone 8 legújabb frissítése
WW_34.1420.1420.407 jelentős javulást hozott a triggereken élvezhető lett vele a játék Call of Dutyba is jelentős javulás triggerek beállítása ultra érzékenyen
Hameerog10
Just updated the phone. Triggers working just fine now. Good job
