02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
03-01-2024 03:17 AM
The team will continue refining the AirTriggers experience in upcoming updates.
03-01-2024 03:29 AM
@Mattias_ASUS Here goes two cents for the problem -
The pressure sensetive mode might be a good option for games like racing games which support pressure sensitive trigger like that in a console but it makes no sense when we use the triggers on FPS games through screen overlay which basically should just mimik screen touch. So a more reliable simple tap mode would be greatly beneficial in this situation. No pressure levels. Just two states - pressed or not. I am sure it can be done with some software trickery.
03-01-2024 03:18 AM
@Unique77k I didn't noticed any change in shoulder trigger they are still performing same as previously. Continuous holding is still buggy. Can't use for shooting in fps game.
03-01-2024 03:21 AM
@Mattias_ASUS i don't think this problem has software solution. Click system not holding the button as is expected.
I am not that much technical but we all hope this should have fix in future.
Thanks.
03-01-2024 03:24 AM
The new AirTriggers are a clickable system and the team is still looking into how to make it better and improve them.
