Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
Unique77k
Rising Star I
I just did the update and it says well that they fixed it..Nothing changed..asus stop releasing mobiles
Vikas_Rathore
Rising Star II
@Unique77k has new update released? Version number?
Fixed something or not?
Nothing my friend same **bleep** again
@Unique77k I knew this will happen cause they really don't care after taking money from the customers.
That's why i already ordered an iPad for gaming .
Unique77k
Rising Star I
@Vikas_Rathore I go to the trigger setting and set the sensitivity to four and again when I press to open the scope it opens and closes
