02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
02-27-2024 07:30 AM
Throw back to them. Useless Phone for the Gamers.
02-27-2024 08:13 AM
You made the biggest mistake of your life. ROG 7 Ultimate was far better way ahead to ROG 8 Pro in terms of gamming performance and trigger technology and cooling technology.
02-29-2024 07:31 AM
I just did the update and it says well that they fixed it..Nothing changed..asus stop releasing mobiles
02-29-2024 07:39 AM
@Unique77k has new update released? Version number?
Fixed something or not?
02-29-2024 07:48 AM
Nothing my friend same **bleep** again
