Split audio volume for media applications.
Dmitriyⁿ
Hello! Is there any possibility to implement the function of separating the sound volume for different media applications, for example, as Samsung did (attached screenshot). For example, you want to play and listen to music at the same time, but the volume of music is equal to the volume of the game, so the gaming process becomes difficult. Also, at the moment, to listen to a voice message, you have to pause the music and after listening to it, play the music again, which is extremely annoying. This feature would allow for more flexibility of system, as well as more enjoyment of the device.
  I would be glad if other users support this idea).
Dmitriyⁿ
Also, I would like to see this feature on all versions of the ROG phone lineup.
Hi!
Thanks for your suggestion, I will forward this to the respective team.
