3 weeks ago
I'm using Asus ROG 7, almost 10 month. Past 2 months I feel that my loud speaker sound was very low, can't listen properly.
3 weeks ago - last edited 3 weeks ago
Hello @madhusmartzz !
Which firmware are you on right now? And I wonder if you could maybe record a video of the phone playing music with another phone.
You can also test if there are any issues with the hardware itself, if you go to the calculator you can trigger an SMMI test by pressing ".12345+=", select "Single test" and press "Speaker Test".
If the test fails then I would advice contacting your closest ASUS Service Center.
3 weeks ago
.12345+= Who made you a moderator?
3 weeks ago
You have used Cooler 7. If you have used Cooler then this problem has occurred, otherwise let the speaker be fixed.
3 weeks ago
At the time of using the cooler 7, an update comes due to which the loudness of the main speaker decreases or no solution has been found yet.
