Rog7 fingerprints&front Camera issue. Need help
teeger
I have rog 7 pro
Very recently I changed frame and lcd for 7 pro which is right prat for me.
After that, Fingerprints and front camera both doesn't work.
Also it looks like stuck in old ver security. I cant update. It doesn't any work at all.
Have you guys faced Similar like this?
All my Rog gear I wish thow away
Mattias_ASUS
If a change was made by an official ASUS Service Center then please return to them because this is not normal.
If not done by the Service Center then there is a risk that something might not be compatible, and outside of warranty.
