ROG Phone 7 low sound speaker
skeitch38
the first time I used it everything felt fine, but after 4 days of using the speaker volume I had a problem, the cellphone has never been dropped or entered by water, which I previously set volume to quarter bar already got a thick and quite loud sound, now with a quarter bar volume it feels quiet and feels like a low end speaker, I have tried to do a factory reset but nothing has changed.
#rogphone7
On build number WW_33.0820.0810.208
Mansi_ASUS
Hey @skeitch38,
Thanks for bringing this to our attention. I'll forward the issue to the R&D, however, before I do that I'd recommend you perform an SMMI test to check if the speaker is working:
  • Open the calculator app, type " .12345+= ", then SMMI Test Interface will pop up.
  • Select "single test" and then "Speaker test"
Already done but the lower speaker is a little bit low volume
Movilianu
Not sure if I should start a new thread but for now I'll jump on this one to say I have the same issue. After I bought it the sound at the middle of the volume slider was loud. At max it was like I owned some dedicated speaker, now for some reason the sound is incredibly low for both speakers. I have to turn it all the way up to max so it sounds as loud as half the volume a month ago.
