display dull, high brightness & low contrast, red tint display with low light bellow 40 %..
Galivents
I am facing a huge issue with the display, red color shift can easily seen all across the display area while scrawling.. also the display is bit reddish.. the display seems dull & also the brightness is high & contrast is low which is making the display looks blurry.
i am not using splendid mode or any other eye protection or any such features. still the above mentioned problems are with me..!!..
there is also issue with gyro delay.. as a professional e-sport player I can observe the difference while playing games like pubg comparing with my old asus zenfone 5z device keeping my gyro sensitivity at highest in rog7..!!..
I tried calibrating gyro sensor but it didn't helped me anyway
5 REPLIES 5
It's the exact same display, difference being you don't have the same motion chip however however it looks like the display circuit seems to be dying over time.
