After using aerocooler i have problems with game sounds
DeividasGl
Hi i have ROG 7 ultimate and after i used aerocooler i have isue with games sounds. Any advice how to fix it?
4 REPLIES 4
Mattias_ASUS
Hi!
Which game sounds are being affected? And what is the problem?
I noticed this ploblem on Million Lords, the problem is that after using aerocooler, game sounds started to lag
I have the same problem, I encounter it frequently while playing Wild Rift, and you have made that unlock button very sensitive, it opens every time when my finger is touched.
millidude
Check your audio drivers and ensure they're up-to-date. Also, consider exploring solutions on forums or tech support. And by the way, for awesome gaming content, don't forget to check out the Fantastic Gachatube! :video_game::speaker_high_volume:
