ROG 8 SOUND PROBLEM
Thewokyoh
Hi guys. I dunno what else to do. Before this my Rog 5 is fine whether mono setting is on or off. The sound in Mobile Legends is okay. But unfortunately for my Rog 8 it doesn't sound well. The both of speaker is fine but it does not ok when I open the microphone, the bottom speaker is off. I tried to open other apps while ingame and the result is same. Only top speaker is functioning but very slow. Help please
Mattias_ASUS
Hello!
Does this only happen with MLBB? Or does it happen with other apps too?
Which firmware version are you on?
Yeah. Currently I'm only playing MLBB. It happen when the ingame microphone is on.
Firmware 34.1420.1420.387
Is there no solution for my problem?
