ROG Phone 6 Pro Hotspot problem
Dustin20021110
I have multiple devices. The Sim card is installed in ROG Phone 6 Pro, so all the other devices connect to its hotspot. When the other devices sleep, they disconnect from its hotspot, but reconnecting when woken up.
I've tried the configurations below:
Security: WPA3, WPA2, WPA2 or WPA3 adaptive
Type: WiFi 6, WiFi 5
AP band: 2.4 GHz, 5 GHz, Dual Band
Turn off hotspot automatically: Never
I've tried all the combinations above, reset all settings and turned off developer options, but this problem is not solved yet.
4 REPLIES 4
Mattias_ASUS
Hello!
May I ask which devices are you trying to connect to the Hotspot?
I've noticed that in some Android devices there is a setting called "Adaptive Connectivity" which turns off the connection to save up on battery life when they go to sleep.
Dustin20021110
Mattias_ASUS
Hello!
Oneplus 6, iPhone 12 Pro Max, MacBook Pro, MSi GF63
They all disconnect when sleeping, but when I install my Sim card in other device, this problem doesn't happen
Danishblunt
Hall of Fame I
Dustin20021110
https://zentalk.asus.com/en/discussion/comment/227739#Comment_227739
its a known bug, it has been reported on the chinese forums quite a while ago.
ASUS_Bot
Rising Star II
