ROG phone 7 charging problem
tamalarolek
My ROG phone 7 charging don't work first I thought my port was broke so I test with another cable and it work.Then I test may adapter and cable with other devices and it's work. What the f..​k is happening? Why there is so many error and bug on such an expensive phone?Any solution for that?
4 REPLIES 4
polpogs
same issue here most especially if it is too hot. it disconnects and reconnects using the original charging brick that came with it.
also, on an anker 120W powerbank, it keeps on negotiating at certain levels. charges between 0.7W to 64ish Wattage. very unstable
sophiaa1212
That's frustrating to deal with, especially on such a premium device like the ROG Phone 7. It sounds like the issue could be with the compatibility of the adapter or cable with the phone's charging system. Sometimes, high-performance devices like gaming phones are more sensitive to certain cables or adapters.
If you're into tech and gaming content, you might also enjoy checking out platforms that provide helpful insights and solutions. There are even resources where you can find apps tailored for entertainment, like this website to make the most of your phone when it’s running smoothly. Hope you find a fix soon!
oh well, the 65W original charging brick should not have any issues 😁. by the way, i lm charging my phone now using anker 120W and it goes a bit further than 65W but most of the time it stays on 0.7W
roguedroid
Rising Star II
Never faced any charging issue on RP 7, but on Poco F2 it's a very common bad issue there.
