ROG Phone 6 able to charge and hypercharge on side port but not main.
Crusoe
I can't charge on the main port but when I flip my cable, it only can fast charge, not hypercharge. However on the side port, It can both hyper charge and charge on both sides of the cable.
(PS, the cable and brick are original ROG)
4 REPLIES 4
Mattias_ASUS
Hi, it sounds like there could be some kind of damage on the bottom USB-C port (Or possibly the cable)
Have you tried using another cable?
Crusoe
The thing is, it works fine on the side port but not the main, however I haven't tried another cable, it might not be the cable's issue.
The best way to see if it's the cable or the port is to try another cable and see what the result is.
I know it sounds odd but I've had stuff like this happening to me and USB-C
Joe9779
I got the same problem, my main charging port sometimes show fast charging, sometimes show hyper charging. And my phone just use only 2 months
