3 weeks ago
Like title says, warranty already ended at the end of October, but it was in the end of warrantry in repair center in Czechia, whrere they replaced motherboard and some tapes.
Sadly issue went back and randomly when i open camera, my phone freeze and then restart to bootloop, only solution how to boot into phone is hold down volume up and power button, boot to bootloader menu and then hit START.
My question is, is there any warranty on replaced motherboard even after end of warranty ?
Thank you for any help.
Best regards
Martin
3 weeks ago - last edited 3 weeks ago
Hi Standy,
If the motherboard was replaced under warranty, it’s likely covered for a period after the repair, even if the main warranty has expired. I recommend contacting the repair center directly to confirm if the replacement parts come with their own warranty. They may be able to assist you with the camera issue if it’s related to the prior repair.
Hope this helps!
Same problem here, Asus Rog Phone 6 shipped for repair almost at the end of warranty in November due to a faulty camera. Replaced motherboard and other components. Since yesterday the camera no longer works again, when I try to open it the message "Camera not ready. Try again later" appears. And the flashlight doesn't even turn on. Even though the warranty has expired I have the same problem I had in November, won't the warranty be extended on the replaced component?
2 weeks ago
downgrade version Below 14 android. 14 android has a critical bug that asus doesn't want to fix, overheating due to incorrect video chip drivers, which heats up the camera.
