No wifi calling in ROG phone 6
Byu
is wifi calling disable in Rog phone 6 ?  or rog phone 6 not support wifi calling?  I tried everythig in seetings, and devereloper option cannnt find the it.
is wifi calling enabled only when carrier support it?  I have checked some carriers like t-mobile plan include unlimited wifi calling.
can anyone explain it?
58 REPLIES 58
Anonymous
Not applicable
Setting/network& Internet/Call/Wlan Call
Yes its disable. You can Aktivate in settings
I didn't see it
Anonymous
Not applicable
Ok,
I think you need a factory reset
Anonymous
Not applicable
Can you tell me your firmware build Version?
