Cooler,Features,Improvments,Bug fixing
excavation5
Rising Star II
So i have the Rog phone 6 and aero active cooler 6
Also i saw somewhere that rog phone 7 have a fast option for aeroactive cooler settings change when play games ....
Why rog phone 6 dont have this option why is so hard to apply this option in rog phone 6 everytime i must exit from the game go in aero active cooler settings and change the speed from there ....
Also why i cant use always bypass charging this is good option i watch movies on my phone use it for navigation also do other thing and bypass charging is good option
Also when i use the Cooler in freezing mode i cant use bypass charging only work whit regular charging that charge my phone to full battery or to the limit 80% the problem here is when i have 50% battery or 60% at night i dont wont to charge my phone more before go to sleep this limit must be smaller becouse i wont to protect my battery better
Another thing is why we dont have a personal profile to set up the phone how to work i dont wont to use Xmode or Dynamic mode to set up my phone
Another problem is when i setup all animation scale to 0 sometimes when i restart the phone or do other things this setting get reset
Other problem is that when i make the phone to use 120hz 144hz or 165hz the GPU stay at max 900mhz no metter what i do and never change his frequency and the problem here is that when the GPU use max speed that make the phone hotter also tehe hove a games that can run at lower gpu speed at 120hz or 144hz whitout a problem also this drain battery a lot is not normal at homescreen to use 900mhz gpu speed at 120hz .... this is in homescreen whitout scroling or do anything i can proof that is a bug i can send a video how in games i can change this speed but its not so easy i must do few things and after this i can use 364mhz for Call of Duty at 120hz and get 120fps stabble
Also why is so hard for R&D department to make some small changes and insert some software features thats dont need so much work Its not normal when new model is made to forget the old one to forget the rog phone 5 and rog phone 6 ...
There are so much small thing that can be changed but this didn't happen and if happened it take a months for this
5 REPLIES 5
Yes and for this reason if they dont change anything about this my next phone will not be rog phone .... Before rog 6 i haved a rog 5 and also whit rog 5 i have same problems i write everywhere whan can be do write about the software Bugs in the problem and what smaller changes can be made but in the end nothing ....the phone is not so bad but the software support for this money is very bad in bulgaria i pay 1200 euro for rog 6 in launch day and for this money i expect more .At the moment cheapest newest versior of red magic 8s Pro is 650 euro whit 8gen 2 and the cheapest version of rog phone 7 is 1150 euro .... And so much money for what ? Whytout the cooler whit price in bulgaria 130 euro you cant play genshin impact at max setting whitout thermal throttle
Now whit my rog phone 6 in genshin impact whitout the cooler i get 48-49-50degrees whit throttling and this is not the biggest problem the biggest problem is that even whit the cooler who is not so cheap i have again CPU throttling and i have a lot FPS drops
