Armoury Crate-Advanced Gaming Tuning- problem
Jeff-11
Model Name: ROG PHONE 6
Firmware Version: 33.0610.2810.166
Rooted or not: NOT ROOTED
Frequency of Occurrence: ALL THE TIME
CAN YOU EXPLAIN THIS?
WHY IT FIX TO 2000MHz on the smaller core is a bug ?
1 ACCEPTED SOLUTION
Accepted Solutions
Delete all old tuning profiles and create new one for every game that you have
So in this case chose" initial value "  create new profile and press "save as" enter name and you are ready
5 REPLIES 5
excavation5
Rising Star II
No before it was a bug 1800mhz i reported this bug and it was fixed .... Your processor speed is
1x 3.2 GHz – Cortex-X2
3x 2.75 GHz – Cortex-A710
4x 2 GHz – Cortex-A510
So in Armory tuning you must have the full potential to adjust your frequency on the way that you wont so real speed is 2000 mhz now the problem is fixed and you can use the full speed of the small cores
Hello thank you for your reply, but on my software version it only stays on 1800mhz.
And does not go higher on 2000mhz
Hi thank you it works for me
