02-05-2023 07:26 AM
Model Name:Rog Phone 6
Firmware Version:32.2810.2212.241
Rooted or not:not
Frequency of Occurrence: Each time used
APP Name & APP Version (If your issue relates to the app): Aero Active cooler 6
My Aero Active 6 cooler keep disconnecting while playing games without any reason, connecting and disconnecting is interrupting my games . I've tried restarting the phone , already installed the lastest software update and cleaned the USB c ports. Auto shutdown settings if mix turn off also was disabled. Any solutions?
07-12-2023 08:04 AM
I connect the kunai using the bumper case (kunai gamepad is set to USB)
07-12-2023 10:16 PM
Also, the fan disconnect when i remove the charging cable. Not from frozen to frosty, but it days fan is removed. Even when it's not. My fan is not loose same with the usb-c cable.
07-19-2023 04:53 AM
@Hecatoncheires @moluskamenace Is this still happening with the new update?
07-19-2023 09:27 AM
I'm not sure if I have updated my Aeroactive cooler 6 and Kunai gamepad. I haven't connected them for a few days. I tried updating them but the automatic update did not appear. So far, I have yet to encounter the problem again. I am still testing. Will update you after a few hours. Thanks
07-20-2023 03:06 AM
Hi @Hecatoncheires Please let me know, thanks
