A problem in Airtriggers
tahahoms
This problem occurred after updating to Android 14 on the phone Rog 6 ، Button problem Airtriggers It does not respond properly, and when you press it, it responds for a second or two and stops working. We hope to fix this problem quickly. I am tired of this problem.
7 REPLIES 7
DanettesD
I have this problem after updating to WW-34.0210.0210.260
Yes, it is the same version of my device after updating to Android 14. I thought I was the only one suffering from this problem and I thought it was a malfunction in my device, but I discovered that there are many people suffering from the same problem after this version of the update.
Hi @tahahoms
Could you share a log to the dev team so that they can see what could be causing the issue? Just use your phone as usual while playing and logging while recreating the issue.
Writing the steps here:
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
How about Asus simply installing a first-person shooter and testing it themselves? I've tried several, it's the same problem everywhere, the air triggers stop shooting in the middle.
