A problem in Airtriggers
tahahoms
This problem occurred after updating to Android 14 on the phone Rog 6 ، Button problem Airtriggers It does not respond properly, and when you press it, it responds for a second or two and stops working. We hope to fix this problem quickly. I am tired of this problem.
7 REPLIES 7
My friend, a lot of people have actually sent you logs and screen recordings and we are facing the same problem. Why do I have to resend the same log for the same error? I don’t understand it. You should see other people’s logs and fix the problem.
Baden7
I also have the same problem with the same version, so I can no longer play and that's the only reason I bought the mobile phone.
Jessieboy22
same on me..but no because of android 14 but because of security patch
