Wifi & Wifi-Hotspot Not Working
freakingrocky
Model Name: ASUS Rog Phone 5
Firmware Version: Android 11 (18.0840.2106.86)
Rooted or not: Not Rooted
Frequency of Occurrence: All the time
So my wifi & wifi-hotspot suddenly stopped working. They won't turn on at all (the hotspot says Error when I try turning it on from this screen). I tried booting into safe mode (doesn't work there also). Tried restarting it several times. Not sure what to do anymore. I don't wanna lose data so if you know how to fix this, Let me know.
515 REPLIES 515
ig_NxVeM
Indiemacho
I am also facing the same issue.
I was an apple user but switched to rog, but i think their software are bad .
Maybe their trick to replace the faulty motherboards
i_liftking
Indiemacho
I am not sure if it's hardware or software fault bro... But their service is pathetic. I now understand why people go with apple. They would upfront replace the phone.
ig_NxVeM
Guys, stop having hope on software update, I bet u 100% it will never fix this issue, basically update crashed the motherboards go get them repaired that's the only solution
donash922
Atleasy give some clairty regarding the issue is this way u treat ur customers?
hp9976802431
Rising Star II
Wifi not turning on
Hotspot not working
Earphone jack not working
If call connect mobile data disconnected
Call volume loudspeaker to low
Open volume high🤕
Any solution?
