01-17-2024 06:59 AM
ROG 5S PRO
33.0210.0210.235
Not rooted
Last night while I was using my phone, it suddenly shut down. As I rebooted it, I cant use the wifi. I can turn on the button but nothing happens. I check if the hotspot is working and found out that it wont turn on. I already follow some guide and tips but it is the same problem. Please help
01-17-2024 08:56 AM
I am experiencing the same problem.
Is there any solution.
01-17-2024 05:09 PM
01-17-2024 05:45 PM
@mckenruo , @RaviJoshi24 , @avedacedavra
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
01-19-2024 09:51 PM
