Wifi and hotspot not working after firmware update 33.0210.0210.242
Retsam
As the title suggest, after this update my wifi and hotspot stopped working.
Falcon_ASUS
@Retsam
According to what you described, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
https://www.asus.com/support/faq/1006657
If the issue persists, I have PM you for confirming your product warranty.
Please check the PM inbox at the top right corner of the screen and kindly provide the requested information.
No nothing works mac address shoes empty, no amount of resetting will work, haven't even used the phone for a year still the warranty shows expired.
