[Urgent fix required] Mobile is not charging with USB A to USB C data cable after the latest update
Model Name: Asus Rog 5
Firmware Version: 18.0840.2201.229
Rooted or not: Not
Frequency of Occurrence: 10/10
Mobile is not charging with USB A to USB C data cable after the latest update. Before the last update the device was charging with all the cable but after after the update I am not able to charge my device at Powerbank, other charger and not ever able to connect my device to Android Auto.
Urgently fix this
ARP_ASUS
Community Legend II
Hi Punisher100192,
If you have recently updated your software version, can you Factory reset your device once.
If even after factory reset it doesn't help try SMMI test to check for hardware related issue
How to Enter SMMI_TEST (test hardware)
Go to Calculator=>type " .12345+= "
you will be entered to SMMI_TEST
FunBike31
Community Legend I
He created 2 discussions for the same problem, the same day,
already answered on the other
