ROG5s battery issue
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
My battery drains fast when using this phone. Does anyone faces the same issue like mine? I just bought this phone yesterday.
RAJU_MSC_MATHEM
Zen Master I
quickvalkyrie2
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
ROG5s battery issue
Wil you check whether the installed applications are started when you start the phone, and continuously runs background without your knowledge.
Note ; I don't have your model phone
Mattias_ASUS
Hello!
Some games are heavier in performance than others and it also depends on if you are using X mode, that will drain your battery faster because the phone will use more resources.
Do you still have this problem?
ASUS_Bot
Rising Star II
