Rog5 a12 issues and poor adaption
Sibi
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Hi Asus i manually updated a12 for Rog5 from ur website and found the a12 to be poorly adapted
the game genie and screenshot settings found inside advance settings both have the "game toolbar" settings available...i think it ended up in 2places due to error...pls look into it and fix this.
The Asus Rog theme has orange/blue accent based on theme applied but the Google apps are in greensih tints this is due to lack of a12 native theme support ..it would be good if u adapt and give the a12 native theme engine like in Zf8!
34 REPLIES 34
Sibi
Rising Star II
ARP_ASUS
Hi Sibi,
Noted the feedback. Let me get back and check on all. If there is any major issue for anyone, the downgrade link is available as well.
Plss look into the themeing issue bro....not a single perskm updated to a12 like the Google apps greenish background tints and green accents that are by default....we need material u themeing.
MANINDER_SINGH
Rising Star I
Sibi
https://zentalk.asus.com/en/discussion/comment/207476#Comment_207476
Download the a12 file from Asus website...move the file from download folder and place it in internal storage....restart and you will see update system prompt...give yes and wait for 10-15mins...it will ask for reboot give yes you will ulbe updated to a12
Thank you so much, should i download ww file?
Sibi
Rising Star II
MANINDER SINGH
https://zentalk.asus.com/en/discussion/comment/207517#Comment_207517
See in your about phone software...if ur software version is we you can download ww
MANINDER_SINGH
Rising Star I
Will i loose data of my phone?
Please find screenshot i have attached.
MANINDER_SINGH
Rising Star I
Sibi
https://zentalk.asus.com/en/discussion/comment/207530#Comment_207530
Will i loose data and apps compatibility of my phone?
