05-08-2021 10:34 PM
05-11-2021 12:17 PM
DanishbluntYes, I know, I also have ROG 3 😁https://zentalk.asus.com/en/discussion/comment/166473#Comment_166473
I mean.... Look at how many people beg for VoLTE and "black crush" fix and yet nothing happened yet 😅
I'm just being realistic here, to be fair as well, performance is currently the least of ASUS's problem as there seem to be a rather massive problem going on with calls getting dropped and so on.
05-11-2021 12:29 PM
wojtekmarchewkaFully equipped with all Rog phones I see 🤣https://zentalk.asus.com/en/discussion/comment/166476#Comment_166476
05-11-2021 06:40 PM
wojtekmarchewkaHere is my Rog3 for comparison to your Rog2 / Rog5:https://zentalk.asus.com/en/discussion/comment/166315#Comment_166315
I tested them on a dolphin emulator with a Nintendo Wii game "Super Mario Galaxy"
If I play without settings in Armory Crate, these are the values of the processor
Game running in full screen in 1080p resolution
Rog 2
Rog 3
When I enabled skip efb access from cpu, on two Rog, we have 60 fps. with the same setting. With Rog 2, this is not a fixed value
With the game resolution set to 2k and full screen, the differences in favor of Rog 5 are greater
Rog 2
Rog 5
05-11-2021 06:40 PM
wojtekmarchewkasince the approval system has something to cry about lets try again:https://zentalk.asus.com/en/discussion/comment/166315#Comment_166315
Rog 2
Rog 3
Rog 2
Rog 5
05-11-2021 06:40 PM
wojtekmarchewkaOnce the mods approved my posts ull see what I mean. Have tested the same on my Rog3 and without skipping EFS i have 47FPS on same settings as you instead of your 34FPS, which is quite a dratsic difference, also ull see my clockspeed of 3100mhz instead of your 850ish.https://zentalk.asus.com/en/discussion/comment/166315#Comment_166315
Rog 2
Rog 3
Rog 2
Rog 5
