Rog phone 5 drain battery issue
AndrewPanda2k
Model Name: Asus ROG phone 5
Firmware Version: add in screenshot
Rooted or not: not
Frequency of Occurrence: everyday for about lat week
APP Name & APP Version (If your issue relates to the app): add in screenshot
Hello, about week ago found that my battery is draining to fast. I got phone from August and everything was fine till that time. As you can see from screenshot battery drain almost straight. I didn't change settings since I get the phone. I'm mostly using dynamic mode. 120hz/60hz. Nothing really changed after I put 60hz. I'm also found that my phone lose about 30 %of battery per night.im using original charger 66w and cable.also I've done factory reset 1 day ago it didn't help. I've tried to find solutions in another topic but i couldn't that's I started a new one. Thank you for any help.
12 REPLIES 12
AndrewPanda2k
k_huat
These photos are still "full device usage" , u need to study the "app usage" n try restrict background battery
Most of my apps are restricted for background battery with wifi, data, Bluetooth, location etc turn off when I sleep n it drain only 2% when I wake up (6-7hours)
Add short screen record
AndrewPanda2k
I'm playing calm of duty on medium settings, before game use about 4%of charge for battle royale(18-20min gaming time) now it's near double
k_huat
Rising Star II
I do not play game at all with my phone, u may need help from other user to verify the battery drain for gaming app.
Others app drainage seems normal for me: try setting tonight with wifi, data, Bluetooth, location etc off before sleep n check how's the drainage next morning
Turn off auto sync n download updates for chrome as well
AndrewPanda2k
Will try tonight
AndrewPanda2k
k_huat
Yesterday I turned of everything, just left dynamic mode(60hz) no Bluetooth no WiFi no data - still 13%per night
