Problem In Asus Rog 5 Wifi Not Working
blaze0855
I have Updated To Android 12 My Wifi Is Not Working And Waiting A Long For Wifi . kindly Check The Problem Asus And Resolve The Issue As Soon As Possible I Am Facing This Lot Of Problem Office Work Is Also Pending .
19 REPLIES 19
ZT-6ba223c6
Rising Star I
ReaperZ_Wolf
Same problem here too. After yesterday's released update which was of 59mb, my wifi has stopped working along with the hotspot. @Gustav_ASUS @TITAN @Irene. Please check to it. I certainly sure that yesterday's update messed up all this wifi issue.
I am not a gamer or do any heavy usage that it will mess up with internal parts. Your software release has caused this issues so request you to kindly send an update asap and fix it
"I certainly sure that yesterday's update messed up all this wifi issue."
Not really.... it's certainly sure that it has nothing to do with the update... aren't the 12424543535 thousand threads with the same issue and explanations enough to get to know this is not a software issue?
ZT-6ba223c6
Rising Star I
ReaperZ_Wolf
"I certainly sure that yesterday's update messed up all this wifi issue." "But this update has created a huge mess."
Not really.. it's certainly sure, this issue has nothing to do with the update. Aren't the other 12534534412 thousands threads enough to get to know it's not a software issue?
ReaperZ_Wolf
Zen Master I
ZT-6ba223c6
https://zentalk.asus.com/en/discussion/comment/205646#Comment_205646
Yeah i know. Have seen these threads before.
But its confusing that how come just after a single update in Android 12 beta ,so many people are reporting the same. Its only after yesterday's update everyone from Android 12 beta are reporting the same issue.
Whatever it is i simply want an downgrade option to verify it myself.
ZT-6ba223c6
Rising Star I
ReaperZ_Wolf
https://zentalk.asus.com/en/discussion/comment/205651#Comment_205651
You can flash the previous android 11 version whenever you want but that won't fix your burnd WiFi chip. Only a motherboard placement can do this.
The update doesn't break it the update just causes a restart which then causes the drivers to reload but since your WiFi chip is burned they can't be loaded -> thus no WiFi
ZT-6ba223c6
Rising Star I
You can flash the previous android 11 version whenever you want but that won't fix your burnd WiFi chip. Only a motherboard replacement can do this.
