[PLEASE] WIFI / HOTSPOT PROBLEM ROG PHONE 5 12/256GB
ARIEF14
Let me introduce myself, I am From Indonesia
I have WIFI problem with my ROG Phone 5 after update
And I try to downgrade again, but its not working, my phone WIFI its still DEAD
If I try to restart my phone, its working but not to long, just 3 Minutes and Crash it again (Restarting)
Please How I Supposed to do, i try everyting in this topic, (Reset Phone, Reset Factory BLA BLA BLA)
AND ITS NOT WORKING
Please Admin
11 REPLIES 11
Hi @FC92 ,
according to your problem, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
 https://www.asus.com/support/faq/1006657/
Also, I have PM you for confirming Wi-Fi issue details.
Could you please check the PM inbox at the top right corner of the screen and kindly provide the requested information?
Hi , I am from India and I am also facing the same problem after Android 13 update . I have tried everything thing from re-start to reboot ( factry reset ) but nothing worked so I kindly want the solution to it .
I have tried to troubleshoot as you said in other conversations but it wouldn't work
Also my warranty has been glitched at myasus app I have purchased this phone at like 20/6/2022 it came after 2 days and tomorrow when I checked up my warranty it is showing that my warranty has been expired on 31/10/2022 so can you explain that
You can update your warrenty by uploading the invoice on the link
https://www.asus.com/in/support/article/1128
Hi ASUS Team,
I also have the same problem with my ROG 5.
After upgrade to Android 13, wifi doesn't work properly.
The_Hames
