06-28-2022 02:24 PM
06-29-2022 03:58 AM
dixingo31.0810.1226.*"92"*!!! is there a new firmware?Please tell us some basic information before asking for help:
- Model Name:Rog Phone 5s
- Firmware Version: 31.0810.1226.92
- Rooted or not: not
- Frequency of Occurrence: permanent
- APP Name & APP Version (If your issue relates to the app): fingerprint sensor
I broke the screen of my Rog Phone 5s so I found a cheap Rog Phone 5 with a dead motherboard. I replaced the dead motherboard with the one from the phone with the broken display. Everything works perfectly apart from the fingerprint sensor. the sensor is connected and the test in the test menu is passing. The problem appears when I try to add a fingerprint - no matter how I place my finger it's not registered. The white dot lights up, but the sensor doesn't register my fingerprint. What can I do to make it work again?
Need help with fingerprint
06-30-2022 07:33 AM
06-30-2022 09:00 AM
06-30-2022 09:54 AM
