Low sound after updating
Tanveer07
Rog 5s
Firmware Version: 33.0210.0210.221
Updated 17/07/2023
After updating Android 13 sound is very low in loudspeaker and in listing music.
Plz help
5 REPLIES 5
Far7799
Go to the setting>sound & vibration>volume adjustment mode and change to stock android. Or just a little bit improvement, untick "sync. wirh volume key" on the right side of volume adjustment.
Hi @Tanveer07
Let us know if you've tried the steps from above. Thanks!
Hi ,any solution do u have
Yes I did nothing happens
