Issue wifi and hotspot after
Sachushakya
There is a issue in wifi and hotspot after a new update so, i am facing a problem in update and backup and restore issue and I want to solve this issue, this will work after a new update....or not ? Tell me
Aureliannn_ASUS
Hi @Sachushakya ,
according to your problem, please refer to the following FAQ to try to troubleshoot your Wi-Fi problem first.
 https://www.asus.com/support/faq/1006657/
Also, I have PM you for confirming Wi-Fi issue details.
Could you please check the PM inbox at the top right corner of the screen and kindly provide the requested information?
