Battery Draining Too Fast
Kaks
Model Name: Asus Rog 5
Firmware Version: 18.0840.2104.56
Rooted or not: No
Frequency of Occurrence:
Rog 5 is draining heating and draining battery too much.Attached the screenshot. Sreenon time about 4 hrs on 92%
5 REPLIES 5
Kaks
I uninstalled messaging app and battery performance somewhat improved. Asus need to optimise applications accordingly.
ARP_ASUS
Community Legend II
Hi Kaks,
The battery graph that you have shared doesn't provide the complete story, the time shown is just an estimation and doesn't actually result in the same SOT(Screen on Time)
Please share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. Settings => Battery => Check the screen & share the same
ReaperZ_Wolf
Zen Master I
Kaks
1.Drain battery to 0,( Phone would switch off by itself, try to turn on and ensure that no more juice left to power it on again)
2. Leave 30 mins,
3. Charge at Switch-off condition to 100,
4. Switch it on the device,
5. Then again Switch off and charge for 30 mins,
6. Unplug and phone to cool down for 30 mins.
Now after 30mins of cool down use you phone as you would.
Try these steps and see how the battery is
Kaks
I will try above steps
