Sudden shut down and phone's temperature is so hot even with no background app running
indra13julius
Model Name: ROG PHONE 3
Firmware Version:
Rooted or not: NOT
Frequency of Occurrence: Always (Since the aforementioned shutdown)
After the initial shut down my phone keeps getting hotter even with no apps running. It stays at 40~43C° and hotter if I open apps.The battery is draining like water too. Restarting or shutting down the phone for awhile does not help. Delete some of my games or useless apps does not help too.
23 REPLIES 23
atmsriram6
Rising Star II
Try to swithon safe mode as stated above it can reslove the issue,
GREEKLEADER
Zen Master I
indra13julius
  1. Model Name: ROG PHONE 3
  2. Firmware Version:
  3. Rooted or not: NOT
  4. Frequency of Occurrence: Always (Since the aforementioned shutdown)
Usually Frame rate affects it,try to see if you indeed have 60hz or 144hz etc.,same with climate,if your room temperature or when you are outside is very warm,and I mean when the sun directly looks at your phone,that can cause the increase in temperature
But I'm guessing it heats up inside the house?Try to specify your room temperature
kompellavedanth
Rising Star I
indra13julius
Same issue here, 39 Celsius and now I can't do anything about this. I want to buy new phone but can't do it.
botboy444
Zen Master I
kompellavedanth
https://zentalk.asus.com/en/discussion/45121/sudden-shut-down-and-phones-temperature-is-so-hot-even-...
39c is normal, on hotter days that's roughly when mine is when gaming, when playing pubg mine hits upto 45
The chips have a max temp on 90c before they'll shut down
kompellavedanth
Rising Star I
botboy444
https://zentalk.asus.com/en/discussion/comment/154475#Comment_154475
But it's very uncomfortable to hold, I have used realme and red magic phone but never faced this issue.
