Sudden fps drops with Bypass charging
RAIDEN_
Rising Star II
Model Name: Rog 3 (12GB + 256GB)
Firmware Version: WW .172
Rooted or not: Not
Frequency of Occurrence: Randomly but most of the time
APP Name & APP Version (If your issue relates to the app): Pubg, Genshin Impact, Call of duty and some more games
Getting some freeze like lags mostly stutters in games if I use Bypass charging while playing it, it is very frustrating please fix it asap
ARP_ASUS
Hi RAIDEN™,
Please share a video
RAIDEN_
Rising Star II
ARP_ASUS
Hi RAIDEN™,
Will dm you soon.
Here I noticed three issues -
1.) Device temperature rise upto 47/48°c if bypass is used.
2.) Sudden fps drop.
3.) Battery gets 1-2% charged after playing like 40minutes or more.
Saifuddin
Zen Master III
RAIDEN™
https://zentalk.asus.com/en/discussion/comment/190872#Comment_190872
Will dm you soon.
which charger you are using and also make sure slow charging is disabled cause with slow charging enabled , mobile will only take 10 watts from charger and if game needs 12 watts than mobile will use remaining 2 watts from battery
As genshin impact requires more than 10 watts at max graphics
