02-04-2021 11:23 PM
02-05-2021 08:24 AM
Gustav_ASUSI will check it out and will be back with more information@Saifuddin Then it's possible your PC is the culprit, like in my case. If you have a second computer/laptop nearby, see if it works with that.
02-05-2021 10:01 PM
Gustav_ASUSJust like you said pc is the culprit , thanks for help 😊@Saifuddin Then it's possible your PC is the culprit, like in my case. If you have a second computer/laptop nearby, see if it works with that.
botboy444Thanks to you also for trying to help 😊😊Not even Charging? Have you got the cooler to test with? If it doesn't work no real issue, just use the bottom one
It might need drivers but mine worked fine with whatever drivers windows installed
02-08-2021 12:38 AM
