Serious heating issue while charging
talwindersinghc
Rising Star II
Gaming and normal tasks are just fine. But rog 3 is heating up crazy while charging. I even tried it charging with areo active cooler on , still heats up . I'm on latest version .78. I tried resetting the phone . Doesn't help. Only possible way to charge my phone without getting it heated up is to power it off and then charge which is not ideal. Asus need to step up their game to solve all the issues rog 3 is experiencing. Rog 3 should be best sd866+ phone but it turn out its in worst ones.
12 REPLIES 12
talwindersinghc
Rising Star II
hank_email_is
What is overheating? Is it like 38C? If so that is ok, but just feel hot to your hand.
I actually blow a fan to the phone when charging, keeping temperature at 31C
Rog has a good heatsink, you just need something to remove it quickly like a fan
Its like 43 degrees. And its not normal. Moreover im talking about charging phone when idle. Not doing anything just charging.
talwindersinghc
Rising Star II
devicentextian
Phone can heat up to 45 degrees some fast charging phone heat up to 60-70 degrees
Not everphone. Atleast not by charging only. If u charge and use your phone then may be but charging when phone is idling. It heats like 43 degrees crazy
talwindersinghc
Rising Star II
kashifi786r
I would return it if I were you mine is on same version and is not having issues it gets max 33 degrees while charging, it could be a fire hazard due to faulty components
No return accepted by asus.
