Firmware Version:17.0823.2008.78
Rooted or not: not rooted
Frequency of Occurrence: Every time.
Model Name:Rog phone 3
Scenario : Bought Phone(ROG Phone 3) on the 22nd October, brought the phone home , tested all functionality.
I am able to charge on the bottom port and side port. Everything works fine.
Midnight came , firmware update came in as phone was booted up only night time.
now its 23rd October , i am no longer able to charge using the bottom port of my phone.
What have i tested?
Use the same charger with a different phone - Yes , charger works
Use different charger with your phone - Only side port works
Factory reset your phone - Yes , i did that. However firmware stays the same. So i am not sure how to downgrade.
There is a side port for charging check if it works there - Yes side port works as mentioned above.
